How to access XSDB using python
I want to know, is there is any way to pass multiple inputs to XSDB from python and get the respective outputs into a python script.
Re: How to access XSDB using python
XSDB supports a TCP server, to which you can connect and issue commands from any client. Check "xsdbserver start -help". Below is an example
Ex. xsdb -eval "xsdbserver start -host localhost -port 12000"
Connecting to this server:
telnet localhost 12000
Trying localhost...
Connected to localhost.
Escape character is '^]'.
help
okay Available Help Categories\n\nconnections   - Target Connection Management\nregisters     - Target Registers\nrunning       - Program Execution\nmemory        - Target Memory\ndownload      - Target Download FPGA/BINARY\nreset         - Target Reset\nbreakpoints   - Target Breakpoints/Watchpoints\nstreams       - Jtag UART\nmiscellaneous - Miscellaneous\njtag          - JTAG Access\ntfile         - Target File System\nsvf           - SVF Operations\n\nType "help" followed by above "category" for more details or\nhelp" followed by the keyword "commands" to list all the commands\n
test
error invalid command name "test"
For each command you send to the server, the reply is preceded with okay/error. You should be able to replace the telnet part with python interface
Hi @vamsikrish95
Don't think so, I mean each time you call to a system call (run xsdb) you will have a different instance of XSDB. I am not aware of any way to keep XSDB running in background and send "commands" from a different CMD.
The only thing I can figure out is just to run a script to perform multiple operation in a single XSDB.
Ibai
Ibai
Trying localhost...
help
test
