Observer cpandya90
How to add larger amount of Block Ram in Design
I am developing a design that transfers a block of data from block ram to ddr using Central DMA. For this I want to add larger amount of block ram. I am able to add 512k of block ram. I can't add more than 512k of block ram. In this design one port of block ram is accessible from processor and other port is accessible from Central DMA block using two bram controllers. Part of my design is shown in given below figure.
Capture.PNG.
Can anybody have an idea how to add more than 512k of block ram and connect with processor and CDMA block?
Scholar u4223374
Re: How to add larger amount of Block Ram in Design
The 7020 has 140 36K block RAMs, although in 8-bit/16-bit/32-bit mode their capacity is reduced to 32KB each. Absolute maximum block RAM is therefore 560KB (in those modes).
Hey @cpandya90,
The amount of available BRAM in an FPGA differs from device to device.
So the first question here is: what device are you designing for?
The second question is: how much memory can your processor handle?
Best,
Herbert
Observer cpandya90
Thanks @hpoetzl
I am doing this design for Zynq-7000 (xc7z020clg484-1).
I am not sure about how much memory processor can handle?
Can you tell me how can I find out this?
Scholar u4223374
Hey @cpandya90,
And for the processor part, it depends on what processor you want to use, but most likely it will be able to handle more memory than available in BRAM resources, which are your primary limitation on this FPGA.
Hope this helps,
Herbert
Scholar hbucher
@cpandya90 Perhaps  I misunderstood but perhaps your question is how to configure the BRAM blocks to have more memory.
This is done in the Address Editor - see "Range".
Observer cpandya90
I tried above mentioned process and I used from 1k to 512k of block ram in my design. After 512k of bram I am not able to validate design with 1M of bram.
Hey @cpandya90,
Well, that was not completely unexpected, after @u4223374 calculated that you only have 560k of BRAM in your FPGA.
Best,
Herbert
