Participant zhengyudennis1
How to add sdk (missed it) after installing vivado 2015.2
Hi all,
   I missed the sdk (forget to select it) when I installed vivado 2015.2. How can I add it now? Thanks much for your help.
Scholar pratham
Re: How to add sdk (missed it) after installing vivado 2015.2
@zhengyudennis1 Check this
http://www.xilinx.com/support/answers/60112.html
Otherwise best option is to uninstall and reinstall with SDK enabled.
-Pratham
Scholar pratham
-Pratham
Visitor varg0050a
Thank you Pratham for the options provided.
I our case we have installed vivado 2015.4 on around 60 computers without slecting some of the Options like SDK and all. Is there any whay we can do a silent install or batch way of doing it, only for missing features?
Aby
