How to add vhdl code in to microblaze?
HI
I have a set of code vhdl and i want to package it and add package in to microblaze?
pr.I used artix-7 50T board FPGA and vivado2017 program
thank you.
Hey @z0x0c0v0b0b
I presume here, that you want to extend the MicroBlaze design and not just wrap up your VHDL code in a tar archive and store it in the MicroBlaze memory ...
There are several options here:
  • Use existing peripherials to exchange data and extend the functionality
  • Create a MicroBlaze peripherial (connected via PLB or OPB)
  • Create a user defined coprocessor/accelerator (connected via FSL)
  • Modify the MicroBlaze HDL code to extend functionality
Hope this helps,
Herbert
You can refer this tutorial
http://www.fpgadeveloper.com/2014/08/creating-a-custom-ip-block-in-vivado.html
Thanks and Regards
Balkrishan
