sanchean
How to configure lwIP for TCP/IP and Microblaze without external RAM
Following on this topic: Solved: Re: AXI EthernetLite -> Vitis errors with lwIP: "F... - Community Forums (xilinx.com),
I am trying now to configure the lwIP library for TCP/IP and a Microblaze system without external RAM.
I've found this thread to be very useful: Solved: How to configure Lwip for Microblaze with BRAM onl... - Community Forums (xilinx.com)
but I am now a bit lost with all the lwIP parameters of the BSP. I'm making my way through them but it is taking some time.
So I was wondering if anyone has succesfully modified and implemented the lwIP library in a Microblaze system with no external RAM?
Thanks in advance,
Andrés
sanchean
Hello again,
I've finally managed to configure lwIP with TCP (no DHCP and no UDP though) and implement it into a Microblaze system without external RAM, just a block RAM of 128K.
For the prove of concept I've implemented the design into an Arty development board (xc7a35ticsg324-1L) with Ethernet interface, using Vivado and Vitis 2020.2. I've used the example application project lwIP Echo Server as the Microblaze base design.
The purpose of the Microblaze system is to implement:
  • Modbus TCP/IP protocol: AXI EthernetLite + AXI Timers
  • UART communication with PC: AXI Uartlite
  • Access to logic external to the block design: AXI GPIOs
First, the Vivado project. This is the block design. The main clock sys_clock is a 100MHz clock and the 25 MHz Ethernet clock for the IC is generated and routed in the top level file.
This is a snapshot of the Vivado address editor:
The configuration of the main IP blocks is the following:
1. Microblaze
2. AXI EthernetLite
3. AXI BRAM Controller
4. Block Memory Generator:
  • Mode is BRAM Controller
  • Safety circuit disabled
Now, the Vitis project.
The first things to do, as explained by @rebakker in this thread Solved: How to configure Lwip for Microblaze with BRAM onl... - Community Forums (xilinx.com), are the following modifications:
1. Changed MEM_ALIGNMENT assignement to 4 in Xilinx lwip202.tcl file in SDK \data\embeddedsw\ThirdParty\sw_service\lwip202_v1_0\data and regenerated BSP. The original memory alignment of 64 is because of the Ultrascale+ A53, and useless for a Microblaze. Insert the following at about line 543.
	switch -regexp $proctype {
            "microblaze" {
				puts $lwipopts_fd "\#define MEM_ALIGNMENT 4"
            default {
				puts $lwipopts_fd "\#define MEM_ALIGNMENT 64"
The following can be placed in main.c to monitor this change.
#if MEM_ALIGNMENT != 4
#error "Change MEM_ALIGNMENT assignement to 4 in Xilinx lwip202.tcl file in SDK \data\embeddedsw\ThirdParty\sw_service\lwip202_v1_0\data and regenerate BSP."
#endif
2. Change PQ_QUEUE_SIZE to 64 in the BSP /microblaze_0/libsrc/lwip202_v1_0/src/contrib/ports/xilinx/include/netif/xpqueue.h. This gave a enormous memory size reduction and the originally 4096 deep queue is way too large for the limited amount of used pbufs. The following can be placed in main.c to monitor this change.
#include "netif/xpqueue.h"
#if PQ_QUEUE_SIZE != 64
#error "Change PQ_QUEUE_SIZE to 64 in project BSP /microblaze_0/libsrc/lwip202_v1_0/src/contrib/ports/xilinx/include/netif/xpqueue.h."
#endif
Then we can proceed with the configuration of the lwip library:
The Stack and Heap size can also be reduced to 0x0400 in the Linker Script file.
To further reduce the size, we can add the compiler flag -Os (optimization for size), both for the BSP and the application project.
And I think that's it. If I forget anything I will update this post.
Cheers,
Andres
sanchean
Hello again,
1. Microblaze
2. AXI EthernetLite
            "microblaze" {
            default {
#endif
#endif
Cheers,
Andres
