How to constraint the BUFR--BUFG clocks ?
HI:
  I am using BUFR with BUFG to generate a clock named clk_div2 divided by 2 from FCLK0(clk_fpga_0) in ZYNQ.
  Should I write constraints between clk_div2 and FCLK0 (clk_fpga_0)? Or the VIVADO can auto constraint the couple clocks so I do not to need to constraint them manually?
 If I constraint them manually , is it enough like this ?
create_generated_clock -name clk_div2_0 -source [get_pins design_1_i/ADC_UNION_64_PORTS/clk_o3_0/clk_div2] -divide_by 2 -add -master_clock clk_fpga_0 [get_pins design_1_i/ADC_UNION_64_PORTS/clk_o3_0/clk_div2]
 I get some inter-clock timing errors in the timing analysis like following ,how can I solve this ? Thanks very much!
there is never a need to add constraints for any buffer elements (or pll/mmcm cells) through which the tool knows how to propagate timing.
The tool should generate the constraints for BUFR-> BUFG output. Please check this before adding manual constraint.
HI
UG903 - Vivado Design Suite User Guide: Using Constraints ( ver2016.2, 5212 KB ) [PDF]
UG906 - Vivado Design Suite User Guide: Design Analysis and Closure Techniques ( ver2016.2, 8001 KB ) [PDF]
Thanks and Regards
Balkrishan
