How to cross compile with ARM R5
I'm trying to cross compile an xml parser libxml2 version 2.9.9 to use as a library in RPU baremetal app.
The compiler for ARM R5 is armr5-none-eabi-gcc.
I write the following command for configuration:
./configure --host=arm-none-eabi --build=none --target=arm-none-eabi --prefix=/home/ubuntu/Documents/libxml2/libxml2_arm CC=armr5-none-eabi-gcc --with-mcpu=cortex-r5
and I get the following error in terminal- configure: error: C compiler cannot create executables
and from config.log:
configure:3611: /tools/Xilinx/SDK/2018.3/gnu/armr5/lin/gcc-arm-none-eabi/bin/armr5-none-eabi-gcc -V >&5
armr5-none-eabi-gcc: error: unrecognized command line option '-V'
armr5-none-eabi-gcc: fatal error: no input files
compilation terminated.
configure:3622: $? = 1
configure:3611: /tools/Xilinx/SDK/2018.3/gnu/armr5/lin/gcc-arm-none-eabi/bin/armr5-none-eabi-gcc -qversion >&5
armr5-none-eabi-gcc: error: unrecognized command line option '-qversion'; did you mean '--version'?
configure:3642: checking whether the C compiler works
configure:3664: /tools/Xilinx/SDK/2018.3/gnu/armr5/lin/gcc-arm-none-eabi/bin/armr5-none-eabi-gcc conftest.c >&5
/tools/Xilinx/SDK/2018.3/gnu/armr5/lin/gcc-arm-none-eabi/bin/../lib/gcc/arm-none-eabi/7.3.1/../../../../arm-none-eabi/lib/libc.a(lib_a-exit.o): In function `exit':
exit.c:(.text.exit+0x2c): undefined reference to `_exit'
collect2: error: ld returned 1 exit status
I am missing something? Is there another way to cross-compile with gcc for arm r5?
yzhang
Some options in the configure file of your libxml2 are not valid for this compiler. Please make sure this library is compatible with arm R5. You can run "armr5-none-eabi-gcc --help" to see valid options for this compiler, and try to replace the options with valid ones.
yzhang
Hey,
Didn't help...
I gave up and used in the project source an header files for a simple xml parser. The easiest way...
