How to debug Linux Applications with SDK2015.1 and Zedboard
Hello, I'm currently trying to debug a Linux application on a Zedboard without success. All the guides (including the one regarding SDK 2015.1) refer to the Debug As -> Debug Configuration -> Remote ARM Linux Application mode, which appears to be missing from my version of the SDK (I'm running it under Linux, if that does matter).
Any ideas? Is that mode discontinued from the 2014 versions onwards?
Thanks a lot
Anonymous
Not applicable
Re: How to debug Linux Applications with SDK2015.1 and Zedboard
Hey,
I have created a tutorial targetting 2014.4 (attached) there are steps towardsa the end for Linux debug in SDK
Hello and thanks,
I've come across this guide but my situation differs in two point.
First of all (I think it's just a matter of version 2015.1 vs 2014.4) when I chose to create a linux project SDK doesn't ask me anymore about the hardware platform project. Secondly, and more importantly, I can't seem to connect to the TCF agent running on my board: the network is properly connected, I can ping the board from my workstation and vice-versa, and the target connection also gets "auto-detected" by the SDK.
Anyway, the debugger will not connect (it will show a connecting... message in the debug view but then it will just hang waiting forever). I checked the petalinux booting procedure on my zedboard console output and i can see "Starting TCF-Agent: OK"
Anonymous
Not applicable
This PDF is a bit old. However, the setting up the debugger for linux is still the same in 2015.1. It sounds like you are still using the default connection. this is not what you want to do, you want to connect to the tcf runnign on your board. Are you following the steps on page 28?
Also, just to test, can you use the images on the wiki to make sure that the issue isnt with your image?
http://www.wiki.xilinx.com/Zynq+Releases
