How to enable GPU mail-400 for x-window(Xorg)
Hi Everyone,
   I adopted ZCU106 VCU TRD 2019.2 from https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/176783395/Zynq%2BUltraScale%2BMPSoC%2BVCU%2BTRD%2B2019.2
I found that Xorg doesn't take advantage of Mali-400 to render visual elements. System resource report of ARM streamline is as follows. CPU 0 is almost exhausted by Xorg whereas GPU usage is 0.
Does anyone know how to to speed up Xorg by Mali-400?
I have checked the ROOFS configuration, libmail-xlnx,libmail-xlnx-dev, packagegroup-petalinux-x11 and packagegroup-petalinux-x11-dev are enabled as follows.
Hi @xela_lin
Did you make sure Xorg log file and xorg.conf file ?
Best regards,
Hi @watari
   Thanks for your help. I don't have idea how to check it, attached files are Xorg log file and xorg.conf file.
Alex
Hi @xela_lin
Would you try debug with modified xorg.conf (change debug option from false to true) ?
Best regards,
@watari
   Thanks for you help. I have enabled debug option as attached file, but i don't have any idea how to see it. how to check whether mail-400 is enabled. Thanks
Alex
Hi @xela_lin
What kind of package are you using (DRM, X, EGEL2 and so on) ?
Also, what kind of backend are you choosing as Mali userland driver ?
According to this log file, it seems package issue and/or Mali backend setting issue.
Would you make sure it ?
Best regards,
The environment is listed below:
1. DRM, X and OpenGL ES are default ones in petalinux 2019.2.
2. Current Mali backend is the default setting in vcu_trd:
lrwxrwxrwx 1 root root 12 Nov 16 08:31 /usr/lib/libMali.so -> libMali.so.9
lrwxrwxrwx 1 root root 14 Nov 16 08:31 /usr/lib/libMali.so.9 -> libMali.so.9.0
lrwxrwxrwx 1 root root 27 Nov 27 03:11 /usr/lib/libMali.so.9.0 -> /usr/lib/x11/libMali.so.9.0
3. Here is our scripts to launch X:
===matchbox===
#/bin/sh
export DISPLAY=:0.0
export XDG_RUNTIME_DIR=/run/user/0/
Xorg&
matchbox-window-manager&
matchbox-desktop&
sleep 3
xrandr --output DP-1 --mode 1920x1080
===wayland===
#/bin/sh
export DISPLAY=:0.0
Xorg&
weston --width=1920 --height=1080 --log=/var/log/weston.log&
sleep 3
