Observer skyfall133
How to fix that " Error downloading program to target" in SDK
I am using Xilinx SDK to debug my code.
But when I want to debug in SDK, this error appears:
I check 2 two hints but they seem oke.
And this is the Address Editor:
Can you help with this problem?
Re: How to fix that " Error downloading program to target" in SDK
select the project, do Right Mouse Button click, click on Generate Linker Script. A dialog comes up with the linker script related settings. Please post that dialog here. e.g:
Raju
Observer skyfall133
Hi @rajut
This is lscript.ld  . I think it seems all right.
Which version of SDK are you using ? Have you tried the Debug with Xilinx System Debugger (instead of GDB). Please let us know
Raju
