Voyager
Voyager
How to get other LWIP reference designs ?
I read "LightWeight IP (lwIP) Application Examples" (xapp1026) file, it said:
The reference design includes these software applications:
Echo server
Web server
TFTP server
TCP RX throughput tes
TCP TX throughput test
But it seems there is only Echo server reference design. So how can I get other reference designs?
Thanks very much.
Voyager
Voyager
Re: How to get other LWIP reference designs ?
Anonymous
Not applicable
All the applications should be there in the application code. However, youy may need to enable the application in the config_apps.h file. This is dowen by defining them as seen below.
#define INCLUDE_ECHO_SERVER    1
#define INCLUDE_WEB_SERVER     1
#define INCLUDE_TFTP_SERVER    1
#define INCLUDE_RXPERF_SERVER  1
#define INCLUDE_TXPERF_CLIENT  1
Note: for optimum performance in a particular applciation. only enable that particular application. For example if you are seeing TXPERF perfomance issues, disable all the other applications
Voyager
Voyager
Thanks for reply. Where can I find this "config_apps.h" header file?
If I want to use application Web server, should I do like this:
#define INCLUDE_ECHO_SERVER 0
#define INCLUDE_TFTP_SERVER 0
#define INCLUDE_RXPERF_SERVER 0
#define INCLUDE_TXPERF_CLIENT 0
Thanks again.
Anonymous
Not applicable
It is in the src directory in the application files delivered with the xapp1026.
Yes, if you want to use just the web_server you would set as follows:
Voyager
Voyager
Hi stephenm, what do you mean "delivered with the xapp 1026"?
xapp 1026 is a pdf file whose title is "LightWeight IP (lwIP) Application Examples".
And it seems I can't find the "config_apps.h" in src folder, please look the attachment.
Anonymous
Not applicable
Try the platform_config.h
Voyager
Voyager
Thanks. But I am totally confused how it works. The different application like Echo server or Web server, should have different source codes. I don't understand why we just need to change the macro definition to achieve different applications.
And in " platform_config.h", it originally does not have these macro definitions. So could you please explain this a little more how it works?
Voyager
Voyager
Hi stephenm, it seems that not all the applications are in the application code. SDK only provides an application which is "LwIP echo sever", in this application, I can't find any other application codes, e.g. Web server. I think I need get them from other sources.
Voyager
Voyager
The SDK template provides only the design for the Echo Server! The Xapp1026 application ( which you can download as a zip file from the xilinx website ) has all the applications in them . The applications are "ifdefed" Thus by setting the corresponding macro you can compile the application.
Arvind
Voyager
Voyager
Thanks, arvindnr. That is what I guess. However, I searched but I can not get the zip file of Xapp1026 applications from Xilinx website. Where do you get it? Do you mind post a link if you have?
Thanks very much.
Voyager
Voyager
Voyager
Voyager
I already got all reference designs. I checked "config_apps.h" file, If I enable echo sever, web sever, TFTP sever at same time as following:
#define INCLUDE_TXUPERF_CLIENT 0
#define INCLUDE_RXUPERF_CLIENT 0
Is this feasible? Will it cause conflict?
Thanks very much.
