shairva
How to get the .HWH file?
As far I have read, the .HWH file is exported inside the .HDF container file.
I can export the .HDF using Vivado, so now, how can I get the .HWH ?
Thanks in advance.
miker
The XSA is a container file.  You can open the XSA file with a program like 7Zip, WinZip, WinRAR, etc.
Please Reply, Kudos, and Accept as Solution.
stephenm
Why do you need the HWH file? you would use the HDF to create the BSP, DT, Petalinux ect..
shairva
I need  the .HWH file for the Xilinx dlet tool
