Observer dbircsak
How to hard reset a board programmatically?
Is there a way to reset a ZC706 board programmatically? Can I send a press command to a pushbutton like the Reset pushbutton?
I see there's commands like XDdr_ResetHw()... anything that will reset the entire board and get it to load from flash again?
Thanks!
Observer dbircsak
Re: How to hard reset a board programmatically?
This worked for me:
xil_printf("Resetting\r\n");
// Taken from ug585-Zynq-7000-TRM.pdf
Xil_Out32(0xf8000008, 0xdf0d); // Must call SLCR_LOCK first
Xil_Out32(0xf8000200, 0x1);
Scholar hbucher
@dbircsak
Not 100% sure it is equivalent but you can start xsdb (<VIVADO>/<VERSION>/bin/xsdb) and issue something like
xsdb / connect / targets <id> / rst -srst
Hi @dbircsak
You can pulse PROGRAM_B.
When PROGRAM_B is pulsed Low, the FPGA configuration is cleared and a new configuration sequence is initiated.
Thanks,Vijay
There is no separate push-button kind of switch to reset the ZC706 board. You need to use ON/OFF power switch to do that.
Observer dbircsak
This is what I'm trying but nothing happens:
#include "xgpiops.h"
int main() {
	int i;
	XGpioPs Gpio;
	XGpioPs_Config *ConfigPtr;
	int Status;
	ConfigPtr = XGpioPs_LookupConfig(XPAR_XGPIOPS_0_DEVICE_ID);
	if (ConfigPtr == NULL) {
		return XST_FAILURE;
	XGpioPs_CfgInitialize(&Gpio, ConfigPtr, ConfigPtr->BaseAddr);
	Status = XGpioPs_SelfTest(&Gpio);
	if (Status != XST_SUCCESS) {
		return XST_FAILURE;
	xil_printf("\r\n");
	for (i = 0; i < Gpio.MaxPinNum; i++) {
//		XGpioPs_SetDirectionPin(&Gpio, i, 0x1); // What does this do?
		XGpioPs_WritePin(&Gpio, i, 0x1);
		xil_printf("%d Dir %u Read %u\r\n", i,
				XGpioPs_GetDirectionPin(&Gpio, i), XGpioPs_ReadPin(&Gpio, i));
	return 0;
Observer dbircsak
This worked for me:
