How to make use of assert?
In a lot of my code I see stuff like this:
	Xil_AssertNonvoid(InstancePtr != NULL);
	Xil_AssertNonvoid(ConfigPtr != NULL);
Sometimes the assert gets triggered and my program just freezes. It would be nice if something would print instead! In this file XilinxProcessorIPLib/drivers/v_hdmirxss/examples/xhdmi_example.c I see they do stuff like this:
void Xil_AssertCallbackRoutine(u8 *File, s32 Line)
	  xil_printf("Assertion in File %s, on line %0d\n\r", File, Line);
  Xil_ExceptionInit();
   * Register the interrupt controller handler with the exception table.
#if defined(__arm__)
  Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_INT,
					   (Xil_ExceptionHandler)XScuGic_InterruptHandler,
					   (XScuGic *)IntcInstPtr);
#else
					   (Xil_ExceptionHandler)XIntc_InterruptHandler,
					   (XIntc *)IntcInstPtr);
#endif
  /* Enable exceptions. */
  Xil_AssertSetCallback((Xil_AssertCallback) Xil_AssertCallbackRoutine);
  Xil_ExceptionEnable();
...so what is this stuff and how do I use it in my code?? Thanks for any help!
Re: How to make use of assert?
This is what I ended up doing:
// Make sure to call Xil_AssertSetCallback
static void AssertPrint(const char8 *file, s32 line) {
	xil_printf("\r\nAssertion in file %s on line %d\r\n", file, line);
void ExceptionHandler(void *data) {
	xil_printf("\r\nException %d\r\nHalting\r\n", data);
	_Exit(0);
int main() {
	print("Starting...\r\n");
	Xil_AssertSetCallback((Xil_AssertCallback) AssertPrint);
	Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_DATA_ABORT_INT,
			ExceptionHandler, (void *) XIL_EXCEPTION_ID_DATA_ABORT_INT);
	// Your code here
	return 0;
	_Exit(0);
int main() {
	// Your code here
	return 0;
