How to modify auto code generated when creating .h files
Hi people,
when we create .h files in Xilinx SDK there is some code automatically generated, specifically -
 * code.h
 *  Created on: 15.01.2016
 *      Author: me
#ifndef SRC_CODE_H_
#define SRC_CODE_H_
#endif /* SRC_CODE_H_ */
I would like to know how to change what is going to be automatically generated when creating .h files?
I am using Xilinx SDK 2016.2
Nenad
I have found it!
when creating new header file, you see this window:
once you press Configure, new window gets opened:
 Then you press Edit and you can modify what will be automatically generated
I have found it!
