Prasanna_K
How to pass arguments to bare metal code in Vitis 2019.2
I am executing one of the benchmark code on both Petalinux and Bare metal. I have successfully executed my code on Petalinux, however, I am not able to execute the code in Vitis as I am not able to pass the arguments to the code. How can I pass arguments in Vitis.
Here's what I did so far, My main function looks something like this and accept command line arguments.
int main(int argc, char **argv) {
My code.....
I cross compile using aarch64-linux-gnu-gcc and get the executable file.
I execute below command on the Petalinux to execute the program and get the expected output.
./ubench --mode compressible --size 65536 --validation 1
Now I am trying to execute the same code on the baremetal using Vitis and  I am trying to  pass arguments in Vitis like this but it didn't work.
I get below error because arguments did not pass and program failed.
#### benchmark configuration ####
# mode: (null)
assertion "strcmp(mode_val, "compressible") == 0 || strcmp(mode_val, "random") == 0 || strcmp(mode_val, "both") == 0" failed: file "../src/ubench_main.c", line 113, function: main
Prasanna
Prasanna_K
System debugger supports cmdline args only for Linux applications. Cannot pass cmdline args for bare metal code on standalone system.
https://forums.xilinx.com/t5/Embedded-Development-Tools/SDK-Standalone-application-passing-arguments-to-main/m-p/997695#M49759
Prasanna_K
