ttambe
How to refresh/reload a source file in XSCT?
In the Xilinx SDK GUI, we can easily refresh/reload a source file (e.g. main.c) from an application project by hitting "F5" or by clicking on "Refresh" on the source file. I would like to do the same thing in XSCT, i.e. without using the Xilinx GUI. But I can't seem to find the correct XSCT command for refreshing a source file. Can someone please help me here?
The reason for wanting to refresh a source file is that once a source file has been edited/updated externally (i.e. outside of the Xilinx SDK GUI), the updates will not be reflected when running the program unless we hit "refresh" on that file.
Thank you,
ttambe
After several trials and errors, the XSCT command to do this is:
projects -build -type app -name <name_of_application_project>
ttambe
