11-16-2009 01:13 AM
I want to transfer video stored in on-board memory ( Spartan 3E starter kit ) over ethernet of Board. For this, first I have to transfer a video file from PC to memory on the kit ( thinking of using Flash ).
I have USB and RS-232 available to connect to the board. I think that I will have to keep a routine in FPGA to accept data from PC over USB and then sending it to Flash memory. Using Microblaze and writing SDK application to trasfer data from PC to Flash should be possible.
Do we have any other way to transfer video file from PC to onboard Flash? any document?
Thank you
Harshal
11-16-2009 01:28 AM
Hello.
I was wondering if you can use the "Program Flash Memory" option in XPS to directly burn your flash with the data.
The binary data can be converted to SREC format using the above option.
