Visitor densarmiento
How to sent buffer data?
Hello Expert,
Good day!
I am a newbie in hardware design(FPGA). right now we're interfacing between camera(OV0706) and zedboard using pmod RS485 as bridge. We created successfully the block design in vivado and generated bitstream file for SDK environment as input. Upon running in SDK environment. My objective is to sent a hexadecimal command and camera give a acknowledgement if the data sent is already receive.
Your response is highly appreciated!
Thank you and Godbless!
EV
Here's my code below;
#include <stdio.h>
#include "platform.h"
#include "xil_printf.h"
#include "xstatus.h"
#include "ps7_init.h"
#include "xscugic.h"
#include "xparameters.h"
#include "xuartlite.h"
#define TEST_BUFFER_SIZE_SEND 5
#define TEST_BUFFER_SIZE_RECV 500
u8 SendBuffer[TEST_BUFFER_SIZE_SEND] = {56, 00, 36, 01, 00}; /* Buffer for Transmit Command */
u8 RecvBuffer[TEST_BUFFER_SIZE_RECV]; /* Buffer for Receiving Data */
XUartLite UartLite; /* Instance of the UartLite Device */
int UartLitePolledExample(u32 DeviceId)
int Status;
* Initialize the UartLite driver so that it is ready to use.
Status = XUartLite_Initialize(&UartLite, DeviceId);
if (Status != XST_SUCCESS) {
xil_printf("UARTLITE DRIVER FAILED");
return XST_FAILURE;
* Perform a self-test to ensure that the hardware was built correctly.
Status = XUartLite_SelfTest(&UartLite);
xil_printf("SELF TEST FAILED");
return XST_FAILURE;
return XST_SUCCESS;
int main()
unsigned char Sent_Count;
unsigned int ReceivedCount = 0;
int sentloop = 0;
int index;
int i;
init_platform(); //INITIALIZE
ps7_post_config(); //ENABLE TO PL
UartLitePolledExample(XPAR_UARTLITE_0_DEVICE_ID); //ENABLE UARTLITE
xil_printf("Start Looping....\n");
for(index = 0; index < TEST_BUFFER_SIZE_SEND; index++){
SendBuffer[index] = SendBuffer[index];
xil_printf("Send ......[%d] = %u\n" ,sentloop,SendBuffer[index]);
sentloop++;
Sent_Count = XUartLite_Send(&UartLite,SendBuffer,TEST_BUFFER_SIZE_SEND);
xil_printf("Send Count... %u\n", Sent_Count);
if (Sent_Count != TEST_BUFFER_SIZE_SEND){
xil_printf("Sent Failed!");
return XST_FAILURE;
while(1) {
ReceivedCount = XUartLite_Recv(&UartLite,RecvBuffer,TEST_BUFFER_SIZE_RECV);
xil_printf("Received count %x\n", ReceivedCount);
for(i=0; i < ReceivedCount; i++)
xil_printf("Received Buffer[%d] = %x\n" ,ReceivedCount,RecvBuffer[i]);
cleanup_platform();
return XST_SUCCESS;
Participant glennparaiso
Re: How to sent buffer data?
Hi @Dhen,
I am also encountered the same problem, hoping that the more experience FPGA users in this forum can give us some enlightment on how to solve the issue.
glenn
Hello Expert,
     Please! give me some of your expert advice with regards to my issues stated above.
Thank you and God bless!
