How to setup SDK2017.4 to compile app for Petalinux 2014.4
I use a Zynq (7015) and Petalinux from Xilinix.
I would like to try and compile Linux user apps using SDK 2017.4 and windows 10 . The target is Petalinux 2014.4 (I have the build on a virtual Linux machine). The problem I have is linking the standard Linux libs. When I create an app I need to specify a 'Linux System Root'  Where do I find that in the old Petalinux build ?
I don't remember having to do that with SDK 2014.4 . In fact making one on that I don't use 'Linux System Root' at all but things compile and I can debug.
Any idea as to what will work?
Re: How to setup SDK2017.4 to compile app for Petalinux 2014.4
See if you can find libraries in this path in older petalinux builds :- <proj_root>build/linux/ rootfs/targetroot/lib/
Best Regards
Shabbir
Hi Shabbir,
Yes I can find that directory, <proj_root>build/linux/ rootfs/targetroot/lib/ on my Ubuntu where I compiled the Linux 2014.4
I am trying to compile the app using SDK 2017.4 on my windows machine, what do I need to do? Copy the Lib directory onto the windows and link to it when I create the app?
thanks
Dave
Hi @davewarren,
I think that copying files from the Linux host to windows might not work completelly due to symbolik links are commonly used on Linux. I would maybe sugget to try to share the folder between both hosts ;)
Ibai
Ibai
