arvindnr
How to solve this error - warning: Internal error: pc 0x777 in read in psymtab, but not in symtab.
I am using EDK 14.1 and I working with a Vertex 4 chip. I get this problem with I try to debug a simple lwip echo server program.
I went through the answer records mentioned here : http://www.xilinx.com/support/answers/21589.htm
I didnt exactly understand the option 1 mentioned in the answer record. How is that exactly done?
However  my main concern is that I should not have to do this!!! Its says this was fixed in EDK 7.1 !!  Is there some other reason this is caused?
Any kind of pointers on how to solve this ?
Arvind
