vanmierlo
Mentor
Mentor
How to split a vector in the IPI?
Using the Vivado IPI I found the concat block to concatenate several signals into a vector. But how should I perform it other way around? How can I split an incoming vector into separate signal lines?
yenigal
Use the Slice block for this function.
Satish
vanmierlo
Mentor
Mentor
Ok, thanks, I found it. Now how can I make the slice block split into several outputs instead picking only one signal? Do I really have to instantiate it for every signal in my vector?
yenigal
Yes,the slice block can output the required slice from the input and doesn't have the feature to distribute all the signals at the output.
You need to use multiple slice blocks if you need multiple slice output's or multiple single outputs from the input signal.
Satish
vanmierlo
Mentor
Mentor
That sucks.
And why the asymmetry? Concat can combine many into one, but slice cannot split one into many. Or the other way around: Slice can only pick one from a vector, but concat can add many to a vector.
cahitugur
Agreed! That sucks!
and after 5,5 years it is still the same :/
