How to swap the core where a project executes after creating the project?
I'm using Xilinx SDK to program a dual-core ARM Cortex-A9 processor. When creating a project, it is possible to select the core where the project executes. Is it possible to select the core after the creation of a project?
Thank you!
Hi @helena
There is no way to change the processor once the BSP project is created, the only thing you could do is to change the BSP of a given application where the other BSP is targeting the second core.
Ibai
Ibai
Hi @helena
Ibai
Ibai
