Voyager
Voyager
How to transfer different type data using ethernet?
I try to use "tcp_write()" function in "tcp.c" to transfer data. However, it seems this function can only transfer "char" type data, if I want to transfer the data like int, short, float through ethernet, what function should I use?
Thanks very much.
Voyager
Voyager
Re: How to transfer different type data using ethernet?
Just typecast it to a character pointer.
Voyager
Voyager
Anybody can help? Thanks.
Voyager
Voyager
Voyager
Voyager
So I guess you mean is, e.g. if we have an int type array, typecast it into a char type array, then transfer it as a char array. After it is received, then typecast it back to int type for further processing, right?
Voyager
Voyager
Your original question was about tcp_write . I dont see how that has anything to do with receiving of data..
Besides that yes if you want to transfer just type cast anything into a character pointer .
Voyager
Voyager
Yes, I only mentioned tcp_write. But the only transfer without receive will be meaningless. And I already tried what you suggested, it works.
Thanks very much.
