julian3434
How to use XSCT and Jtag tool to burn BSP file into NandFlash?
After i installed the new version SDK(2018.1), I found that XMD tool has been removed, and it turn into XSCT. When i used XSCT and Jtag tool to burn BSP file into NandFlash of my board, like burning used XMD before, but i couldn't stop uboot console, where can burn BSP files with NandFlash commands. How to use XSCT correctly?
abommera
Hi @julian3434 ,
Please refer UG1208 (v2018.1), page no.99 to create a bootable image and programming the flash.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug1208-xsct-reference-guide.pdf
Thanks & Regards
Anil B
julian3434
Thanks for your help. I can use XSCT and Jtag tool to burn BSP file into NandFlash of board now, after I used the command "rst" to stop processor running.
But I meet another issue below:
U-Boot 2018.01 (Oct 29 2019 - 19:57:53 -0700)
Model: Zynq Zed Development Board
Board: Xilinx Zynq
Silicon: v3.1
DRAM:  ECC disabled 240 MiB
MMC:   Card did not respond to voltage select!
mmc_init: -95, time 23
sdhci@e0101000 - probe failed: -95
mmc_init: -95, time 24
It seems that the boot mode of uboot default configure is MMC/SD card, so how to modify configure file into the mode boot from NandFlash?
Thanks in advance.
