Visitor quan0602
How to use lwip141 in vivado2019.1
Why can I only choose lwip211?
Re: How to use lwip141 in vivado2019.1
Hi @quan0602.,
From this Wiki_Page, it is mentioned that lwip141 is deprecated and will be removed from the repository subsequently.
Best regards,
Abdallah
The tools will prompt you to use the most uptodate version of the libraries. However, you can use older ones.
You need to change this in the SDK install:
2019.1\data\embeddedsw\ThirdParty\sw_services\lwip141_v2_0\data\lwip141.mld
Remove the line below
OPTION library_state = "deprecated";
You might need to close, and repoen SDK
Then if we create a BSP, we can see the library we added:
