Observer phil_vefxi
How to use microblaze QEMU to test?
I thought that perhaps it would be a bit quicker to use QEMU for microblaze (info here: http://www.wiki.xilinx.com/QEMU ) for testing an elf generated from the SDK. That way I figure that I could make changes to the c code, recompile and try it quickly on QEMU.
How would I go about doing that? I'm using the webserver reference design (from: http://www.xilinx.com/support/documentation/application_notes/xapp1026.pdf)  I've got an elf file and an mfs file which contains the index.html, javascript, etc. Now how would I go about running this on QEMU? I'm thinkng that somehow I need to combine the .elf file and mfs file into an iso which QEMU reads in.
Has anyone tried doing this?
Phil
Re: How to use microblaze QEMU to test?
To use QEMU there are a few set of peripherals that are supported when using QEMU.
Refer to page 4 of this document http://www.xilinx.com/support/documentation/sw_manuals/petalinux2014_2/ug982-petalinux-system-simulation.pdf
The procedure of using QEMU is mentioned in the same document.
--Hem
Observer phil_vefxi
Does that doc also apply to standalone and xilkernel applications? I've got a xilkernel application with an elf file and an img file, no LInux involved.
