Visitor pocero
How to use the external memory in the best way
I'm working on an EDK project in which I have to use the external memory.
Currently, the external DDR memory is mapped like this (in EDK addresses tab):
Instance: DDR_SDRAM, Base name: C_MPMC_BASEADDR, Base Address = 0x80000000, High Address = 0x81FFFFFF, Size = 32M
The problem is that I want to use that memory for several purposes:
1) To load the program (elf) into external memory
2) To use the external memory as a video memory for xps_tft IP
3) To use the xil_mfs system into the external memory
I set the base address to the video memory, so when loading the program into external memory, I should manually edit the Linker Script file to avoid overlapping. For example (from the linker script):
MEMORY
   ilmb_cntlr_dlmb_cntlr : ORIGIN = 0x00000050, LENGTH = 0x00003FB0
   DDR_SDRAM_MPMC_BASEADDR : ORIGIN = 0x80000000, LENGTH = 0x001FFFFF --> I edit the length here
   PROGRAM_MEM : ORIGIN = 0x81000000, LENGTH = 0X00020000 --> I add this line
Finally, to initialize the file system (xil_mfs_init instruction), I also have to insert the address manually.
What I would like to know is a better way to define those memory segments from EDK, for example to define:
2 MB for video memory
2 MB for program (elf)
4 MB for file system
(all of them from the same external DDR memory) then to have a parameter for each memory segment (for example VIDEO_BASEADDR, FILE_BASEADDR...) and to know that they won't overlap.
Re: How to use the external memory in the best way
Your current method is correct and good enough.
It takes more time to make the tool generate your expected format automatically than edit it manually if you did well comment in your code.
Visitor pocero
OK, I thought that was not the right method to do it.
Thank you very much.
