How to verify elf file in XSCT
I have downloaded an Elf file using dow command. Then I continue con to run the application. I am wondering if I need to Verify then at which stage I should do it ? I have tried verify command after I stop but verification was failed. I have specified Elf file with full path as in dow command.
Re: How to verify elf file in XSCT
I actually never verify the elf is downloaded to memory. However, if you where to do it, then do it after the dow and before con
The path is relative to the directory you are executing XSCT from.
 Also since this is tcl, y ok can use glob, file tail and rootname ECT to parse the path.
what version of XSCT are you using. The verify command is documented in the XSCT user guide (see page 36)
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1208-xsct-reference-guide.pdf
However, in older versions this was called elfverify
You can also dump the ELF (using objdump), and use (Assuming Zynq Ultrascale)
  • targets -set -filter {name =~ "Cortex-A53 #0"}
  • mrd 0x<memory Address> 0x100
This will read the first 0x100 address locations, you can cross check this against the objdump'ed elf.
I am using 2017. 3
After downloading ELF file using dow command, Do I need to run verify command before or after con command which execute the ELF file. Another question I am using dow and fpga commands with full path of the file. Is there any way to give path after the the current directory ?
