Howto use the Tri-Mode Ethernet MAC?
Hi all,
I have a Virtex 4 FX development board and I would like to use the available embedded PowerPC and Tri-Mode Ethernet MAC for a design. Can anyone please point me to a simple example on using the embedded Ethernet MAC.
Best regards,
Sergio Rui Silva
Hi Sergio Rui Silva,
Check the EDK Example at http://www.xilinx.com/ise/embedded/edk_examples.htm, please.
--XF
Thanks for the reply! So I add the hard_temac and plb_temac IP cores to the design. Connect the plb_temac to the plb bus, but then how do I specify the physical conection of the hard_temac to the FPGA pins?
Best regards,
Sergio Rui Silva
