I WANT TO CREAT A CUSTOM IP,I AM FAILURE TO WRITE TestApp_Peripheral.c file
I am attaching my user logic code.Please help me to create .c file corrosponding to the user logic.Please help me.
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
library proc_common_v3_00_a;
use proc_common_v3_00_a.proc_common_pkg.all;
-- DO NOT EDIT ABOVE THIS LINE --------------------
--USER libraries added here
-- Entity section
-- Definition of Generics:
-- C_SLV_DWIDTH -- Slave interface data bus width
-- C_NUM_REG -- Number of software accessible registers
-- Definition of Ports:
-- Bus2IP_Clk -- Bus to IP clock
-- Bus2IP_Reset -- Bus to IP reset
-- Bus2IP_Data -- Bus to IP data bus
-- Bus2IP_BE -- Bus to IP byte enables
-- Bus2IP_RdCE -- Bus to IP read chip enable
-- Bus2IP_WrCE -- Bus to IP write chip enable
-- IP2Bus_Data -- IP to Bus data bus
-- IP2Bus_RdAck -- IP to Bus read transfer acknowledgement
-- IP2Bus_WrAck -- IP to Bus write transfer acknowledgement
-- IP2Bus_Error -- IP to Bus error response
entity user_logic is
generic
-- ADD USER GENERICS BELOW THIS LINE ---------------
--USER generics added here
-- ADD USER GENERICS ABOVE THIS LINE ---------------
-- DO NOT EDIT BELOW THIS LINE ---------------------
-- Bus protocol parameters, do not add to or delete
C_SLV_DWIDTH : integer := 32;
C_NUM_REG : integer := 15
-- DO NOT EDIT ABOVE THIS LINE ---------------------
port
-- -- ADD USER PORTS BELOW THIS LINE ------------------
-- clk : in STD_LOGIC;
-- rst_n : in STD_LOGIC;
-- start : in STD_LOGIC;
-- din : in STD_LOGIC_VECTOR (63 downto 0);
-- din_valid : in STD_LOGIC;
-- buffer_full : out STD_LOGIC;
-- last_block : in STD_LOGIC;
-- ready : out STD_LOGIC;
-- dout : out STD_LOGIC_VECTOR (63 downto 0);
-- dout_valid : out STD_LOGIC;
--USER ports added here
-- ADD USER PORTS ABOVE THIS LINE ------------------
-- Bus protocol ports, do not add to or delete
Bus2IP_Clk : in std_logic;
Bus2IP_Reset : in std_logic;
Bus2IP_Data : in std_logic_vector(0 to C_SLV_DWIDTH-1);
Bus2IP_BE : in std_logic_vector(0 to C_SLV_DWIDTH/8-1);
Bus2IP_RdCE : in std_logic_vector(0 to C_NUM_REG-1);
Bus2IP_WrCE : in std_logic_vector(0 to C_NUM_REG-1);
IP2Bus_Data : out std_logic_vector(0 to C_SLV_DWIDTH-1);
IP2Bus_RdAck : out std_logic;
IP2Bus_WrAck : out std_logic;
IP2Bus_Error : out std_logic
attribute SIGIS : string;
attribute SIGIS of Bus2IP_Clk : signal is "CLK";
attribute SIGIS of Bus2IP_Reset : signal is "RST";
end entity user_logic;
-- Architecture section
architecture IMP of user_logic is
--USER signal declarations added here, as needed for user logic
signal clk : STD_LOGIC;
signal rst_n : STD_LOGIC;
signal start : STD_LOGIC;
signal din : STD_LOGIC_VECTOR (63 downto 0);
signal din_valid : STD_LOGIC;
signal buffer_full : STD_LOGIC;
signal last_block : STD_LOGIC;
signal ready : STD_LOGIC;
signal dout : STD_LOGIC_VECTOR (63 downto 0);
signal dout_valid : STD_LOGIC;
-- Signals for user logic slave model s/w accessible register example
signal slv_reg0 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg1 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg2 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg3 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg4 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg5 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg6 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg7 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg8 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg9 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg10 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg11 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg12 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg13 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg14 : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_reg_write_sel : std_logic_vector(0 to 14);
signal slv_reg_read_sel : std_logic_vector(0 to 14);
signal slv_ip2bus_data : std_logic_vector(0 to C_SLV_DWIDTH-1);
signal slv_read_ack : std_logic;
signal slv_write_ack : std_logic;
component keccak is
Port ( clk : in STD_LOGIC;
dout_valid : out STD_LOGIC);
end component;
begin
clk <= Clk;
rst_n <= rst_n;
start <= start;
din <= din;
din_valid <= din_valid;
buffer_full <= buffer_full;
last_block <= last_block;
ready <= ready;
dout <= dout;
dout_valid <= dout_valid;
sha_keccak: entity keccak
port map(
clk=>Bus2IP_Clk,
rst_n=>Bus2IP_Reset,
start=>slv_reg2(0),
din=>din,
din_valid=>slv_reg3(0),
buffer_full=>slv_reg4(0),
last_block=>slv_reg5(0),
ready=>slv_reg6(0),
dout=>dout,
dout_valid=>slv_reg9(0)
--USER logic implementation added here
-- Example code to read/write user logic slave model s/w accessible registers
-- Note:
-- The example code presented here is to show you one way of reading/writing
-- software accessible registers implemented in the user logic slave model.
-- Each bit of the Bus2IP_WrCE/Bus2IP_RdCE signals is configured to correspond
-- to one software accessible register by the top level template. For example,
-- if you have four 32 bit software accessible registers in the user logic,
-- you are basically operating on the following memory mapped registers:
-- Bus2IP_WrCE/Bus2IP_RdCE Memory Mapped Register
-- "1000" C_BASEADDR + 0x0
-- "0100" C_BASEADDR + 0x4
-- "0010" C_BASEADDR + 0x8
-- "0001" C_BASEADDR + 0xC
slv_reg_write_sel <= Bus2IP_WrCE(0 to 14);
slv_reg_read_sel <= Bus2IP_RdCE(0 to 14);
slv_write_ack <= Bus2IP_WrCE(0) or Bus2IP_WrCE(1) or Bus2IP_WrCE(2) or Bus2IP_WrCE(3) or Bus2IP_WrCE(4) or Bus2IP_WrCE(5) or Bus2IP_WrCE(6) or Bus2IP_WrCE(7) or Bus2IP_WrCE(8) or Bus2IP_WrCE(9) or Bus2IP_WrCE(10) or Bus2IP_WrCE(11) or Bus2IP_WrCE(12) or Bus2IP_WrCE(13) or Bus2IP_WrCE(14);
slv_read_ack <= Bus2IP_RdCE(0) or Bus2IP_RdCE(1) or Bus2IP_RdCE(2) or Bus2IP_RdCE(3) or Bus2IP_RdCE(4) or Bus2IP_RdCE(5) or Bus2IP_RdCE(6) or Bus2IP_RdCE(7) or Bus2IP_RdCE(8) or Bus2IP_RdCE(9) or Bus2IP_RdCE(10) or Bus2IP_RdCE(11) or Bus2IP_RdCE(12) or Bus2IP_RdCE(13) or Bus2IP_RdCE(14);
-- implement slave model software accessible register(s)
SLAVE_REG_WRITE_PROC : process( Bus2IP_Clk ) is
begin
if Bus2IP_Clk'event and Bus2IP_Clk = '1' then
if Bus2IP_Reset = '1' then
slv_reg0 <= (others => '0');
slv_reg1 <= (others => '0');
slv_reg2 <= (others => '0');
slv_reg3 <= (others => '0');
slv_reg4 <= (others => '0');
slv_reg5 <= (others => '0');
slv_reg6 <= (others => '0');
slv_reg7 <= (others => '0');
slv_reg8 <= (others => '0');
slv_reg9 <= (others => '0');
slv_reg10 <= (others => '0');
slv_reg11 <= (others => '0');
slv_reg12 <= (others => '0');
slv_reg13 <= (others => '0');
slv_reg14 <= (others => '0');
else
case slv_reg_write_sel is
when "100000000000000" =>
for byte_index in 0 to (C_SLV_DWIDTH/8)-1 loop
if ( Bus2IP_BE(byte_index) = '1' ) then
slv_reg0(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "010000000000000" =>
slv_reg1(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "001000000000000" =>
slv_reg2(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "000100000000000" =>
slv_reg3(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "000010000000000" =>
slv_reg4(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "000001000000000" =>
slv_reg5(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "000000100000000" =>
slv_reg6(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "000000010000000" =>
slv_reg7(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "000000001000000" =>
slv_reg8(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "000000000100000" =>
slv_reg9(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "000000000010000" =>
slv_reg10(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "000000000001000" =>
slv_reg11(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "000000000000100" =>
slv_reg12(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "000000000000010" =>
slv_reg13(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when "000000000000001" =>
slv_reg14(byte_index*8 to byte_index*8+7) <= Bus2IP_Data(byte_index*8 to byte_index*8+7);
end if;
end loop;
when others => null;
end case;
end if;
end if;
end process SLAVE_REG_WRITE_PROC;
-- implement slave model software accessible register(s) read mux
SLAVE_REG_READ_PROC : process( slv_reg_read_sel, slv_reg0, slv_reg1, slv_reg2, slv_reg3, slv_reg4, slv_reg5, slv_reg6, slv_reg7, slv_reg8, slv_reg9, slv_reg10, slv_reg11, slv_reg12, slv_reg13, slv_reg14 ) is
begin
case slv_reg_read_sel is
when "100000000000000" => slv_ip2bus_data <= din(31 downto 0);
when "010000000000000" => slv_ip2bus_data <= din(63 downto 32);
when "001000000000000" => slv_ip2bus_data(0) <= start;--slv_reg2;
slv_ip2bus_data(1 to 31) <= (others => '0');
when "000100000000000" => slv_ip2bus_data(0) <= din_valid;--slv_reg3;
when "000010000000000" => slv_ip2bus_data(0) <= buffer_full;--slv_reg4;
when "000001000000000" => slv_ip2bus_data(0) <= last_block;--slv_reg5;
when "000000100000000" => slv_ip2bus_data(0) <= ready;--slv_reg6;
when "000000010000000" => slv_ip2bus_data <= dout(31 downto 0);--slv_reg7;
when "000000001000000" => slv_ip2bus_data <= dout(63 downto 32);--slv_reg8;
when "000000000100000" => slv_ip2bus_data(0) <= dout_valid;--slv_reg9;
when "000000000010000" => slv_ip2bus_data (0 to 31)<= (others => '0');--slv_reg10;
when "000000000001000" => slv_ip2bus_data (0 to 31)<= (others => '0');--<= slv_reg11;
when "000000000000100" => slv_ip2bus_data (0 to 31)<= (others => '0');-- slv_reg12;
when "000000000000010" => slv_ip2bus_data (0 to 31)<= (others => '0');-- slv_reg13;
when "000000000000001" => slv_ip2bus_data (0 to 31)<= (others => '0');-- slv_reg14;
when others => slv_ip2bus_data <= (others => '0');
end case;
end process SLAVE_REG_READ_PROC;
-- Example code to drive IP to Bus signals
IP2Bus_Data <= slv_ip2bus_data when slv_read_ack = '1' else
(others => '0');
IP2Bus_WrAck <= slv_write_ack;
IP2Bus_RdAck <= slv_read_ack;
IP2Bus_Error <= '0';
end IMP;
