I could not launch xps-sdk(java virtual machine failed!)
If i launched sdk from edk menu "software->launch platform sdudio sdk", a dos condole passed and then nothing appeared. If i launched sdk from windows start menu, java virtual machine failed. Has anyone experienced this? Thank you a lot!
can you cut & paste the error message ?
Matteo
I'm having the same problem.
After starting the SDK from windows startup menu
I get the following messages from a message window
Java virtual machine launcher: "Could not find the main class. Program will exit."
Can anyone enlight us?
I had a similar problem when opening a project with a path containing spaces.
I removed the spaces in the path and the SDK could be launched OK.
Hope this helps.
G.
I have this problem as well and have verified that there are no spaces in any part of the path.
If I try to "Launch Platform Studio SDK" from XPS the first error is the java virtual machine error
http://picasaweb.google.com/lh/photo/ZBGbj1cs1FxVmTpAVXiSaA?feat=directlink.
When I "ok" this I get the second error.
 http://picasaweb.google.com/lh/photo/CiGDnkVzCdOLvYa2BLkScw?feat=directlink
Does anyone know why this is happening?  I do remember having to change some java settings to use CoreGen.  Thanks
I has the same issue,
I solve it by uninsatall  last Java update 7 from Control panel
worked for me
Itamar
