rowesca
I2C and microblaze problems
Hello all b4 the weekend i had working i2c, but since yesterday it stopped working, on my logic analyzer i can see it drops for like 10us low on the SDA line and that is about it. i tried it with my previous code(which worked b4) and with the repeated start example. Always the same result. Any one any idea? i use the arty board. also i get these errors at the start of SDK:
ROR : (XSDB Server)ERROR: [Hsi 55-1594] Core cpu of version 1.13.a not found in repositories
ERROR: [Hsi 55-1594] Core v6_ddrx of version 2.00.a not found in repositories
21:40:06 ERROR : (XSDB Server)ERROR: [Hsi 55-1594] Core emaclite of version 3.03.a not found in repositories
ERROR: [Hsi 55-1594] Core uartlite of version 2.00.a not found in repositories
ERROR: [Hsi 55-1594] Core axidma of version 5.00.a not found in repositories
ERROR: [Hsi 55-1594] Core iic of version 2.04.a not found in repositories
ERROR: [Hsi 55-1594] Core intc of version 2.04.a not found in repositories
ERROR: [Hsi 55-1594] Core tmrctr of version 2.04.a not found in repositories
ERROR: [Hsi 55-1594] Core axivdma of version 4.00.a not found in repositories
ERROR: [Hsi 55-1594] Core bram of version 3.01.a not found in repositories
ERROR: [Hsi 55-1594] Core standalone of version 3.05.a not found in repositories
21:40:06 ERROR : (XSDB Server)ERROR: [Hsi 55-1452] Error: running open_sw_design.
21:40:06 ERROR : [Common 17-39] 'hsi::open_sw_design' failed due to earlier errors.
21:40:06 ERROR : (XSDB Server)ERROR: [Hsi 55-1594] Core cpu of version 1.13.a not found in repositories
21:40:07 INFO : Unable to read in MSS file C:\Users\Roy\Desktop\SDK_Workspace\bsp\system.mss : null
21:40:07 ERROR : (XSDB Server)ERROR: [Hsi 55-1594] Core cpu of version 1.13.a not found in repositories
21:40:07 ERROR : (XSDB Server)ERROR: [Hsi 55-1594] Core v6_ddrx of version 2.00.a not found in repositories
21:40:07 ERROR : (XSDB Server)ERROR: [Hsi 55-1594] Core uartlite of version 2.00.a not found in repositories
21:40:07 ERROR : (XSDB Server)ERROR: [Hsi 55-1594] Core axidma of version 5.00.a not found in repositories
21:40:07 ERROR : Failed in generating sources
could these relate to my problem? never noticed them before but to be honoust never had any problems so didn't look anywhere else than my code.
rowesca
The errrors i fixed, only the I2C not. I found out that that going low and high again is probably the start comando on the SDA line. and than it does nothing
htsvn
hi,
what is the device that you would want to interface with i2c controller? Is this a xilinx development board or a custom board?
--hs
rowesca
It is my on custom boad. but this also happends when i only hang my logic analyzer on the pins.
lucileklang
How did you do to solve the "ERROR: [Hsi 55-1594] Core [...] of version 2.00.a not found in repositories" ?
I have the same problem with
ERROR : (XSDB Server)ERROR: [Hsi 55-1594] Core gpio of version 4.1 not found in repositories
ERROR : (XSDB Server)ERROR: [Hsi 55-1594] Core iic of version 3.2 not found in repositories
Could someone post a solution please ?
pvempati
This issue is due to drivers are not available in SDK repository. Please check the driver is available in that folder or not.
Drivers location: <SDK_installed_path>/data/embeddedsw/XilinxProcessorIPLib/drivers
And also check if you already added any repo using Menu in SDK GUI Xilinx_tools/repository/
In general this issue comes, if BSP is unable to find the driver in specified path.
Thanks & Regards,
Praveen Kumar. V
