I2C / xps_IIC does not sending data
Hi ,
I am trying to send data to an image sensor registers through the I2C  core in the EDK. The problem is I can not send any thing and I got zero sent byte. I am using the following alogrithm
1. put the address of the internal register and the data into one array
2. send the array using XIic_Send function
3. check the return value of the function till the number of sent bytes is equal the size of the register address and the data byte size.
In C :
Do {
sendbytecount = XIic_Send(IIC_Base_ADDRESS, CMOS_ADDRESS, writebuffer, sizeof(address)+data_size, XIIC_Stop)
} while ( sendbytecount ! = sizeof(address)+data_size);
Please could you help me.
Re: I2C / xps_IIC does not sending data
Hi all ,
I have solved the problem of the I2C bus using I2C scope analyzer. I discovered that the FPGA shifts the slave address one position to the left, So I had to change the slave address a little bit to ensure that the right address is sent to the slave device. for example 0x90 is changed to 0xC8.
Thanks for all who tried to help me .
Scholar drjohnsmith
first rule of debugging, devide and conqure.
 So are you in hardware or simulation ?
  have you looked with a scope to see what actual voltages are moving on the I2C lines ?
hi ,
thank you for your reply.
I used a scope to check the I2C pins. I can only use the I2C to send one byte successfully. When I try to send an array of bytes , the voltage in the I2C pins does not change(stays in high state without changes). I checked that also using the the software by printing the number of bytes that has been sent and I found that it works only when I put one byte. I use XIic_Send function.
PLease do you have some examples or app note ? That may help me .
Scholar drjohnsmith
have you seen this Xapp  ?
http://www.xilinx.com/support/documentation/ip_documentation/xps_iic.pdf
pages in the area of P27 show you the pseudo code you need.
 One other thing,
are you getting the ACK condition on the I2C ?
I guess if the controler does not get the ACK, it's not going to get past the first byte.
Message Edited by drjohnsmith on 24-08-2009 09:03 PM
If you are using IIC high level driver, please make sure that the IIC interrupt has been connected to INTC.
-XF
the XIic_Send method cancels when the address write transfer has not been  aknowledged.
Therefore you see exactly one byte on the i2c bus!
- Is the slave-id correct??
- Is the i2c frequency to high?
- Are the pullups connected??
- Is the voltage pegel (TTL/CMOS) suitable??
Cheers,
Kai
Scholar drjohnsmith
did you find an answer to this
Hi all ,
I am dealing with the same problem of writing via I^2c with the function
XIic_Send. The result of this function is that no bytes were sended.
You mentioned connecting pullups, can you explain what could I do if I am using Nexys2-500  FPGA board?
thanks,
haz88
Re: I2C / xps_IIC does not send data
How can I check that?
thanks,
haz88
I'm using Nexys2-500 board and a digilent's video decoder. I need to configure the registers in the board via I2C.
In my design, there is a XPS IIC Interface. I used the XIic_Send function and only the first byte of the slave address is transmitted but with no acknowledge while all of the other bytes that include subaddresses and data aren't. I am sure that the slave address is right and I also know via debbuging that the program gets stuck in the part that statusReg should get a value. What could cause this problem.
Looking forward for your reply,
haz88
P.s
 The source file that I am using, is attached to this message( the while statement around the XIic_Send is for seeing the signals on the scope).
