IDELAYCTRL generation by MIG
Hello.
I am trying to implement DDRII controller.
The UCF generated by MIG contains 4 IDELAYCTRLs whereas max C_NUM_IDELAYCTRL parameter value is 3 in EDK DDRII GUI. That means i can only instantiate 3 IDELAYCTRLs in EDK.
So what about the fourth one and if it is true then which 3 i have to use which one to reject??
Waiting for your valuable suggestions.
Regards.
Best of luck.
Unlimited in my Limits.
Observer sbonafede
Re: IDELAYCTRL generation by MIG
I, too, just ran into this when messing around with a custom DDR2 MIG compatible design for a V5FX design.  (The peripheral: ppc440mc_ddr2_v2_00_a)
See page 5 of DDR2 Memory Controller for PowerPC 440 Processors [DS567 (v1.3)].
Looking at the verilog, there's a generate statement to instantiate the idelay controllers and so it should be possible to hack the mpd file to allow for more than 3 IDELAYCTRL...
EDIT:  Just noticed that the original poster is implementing a DDRII controller and I'm implementing a DDR2 controller.
Message Edited by sbonafede on 05-11-2009 04:12 PM
Visitor adetel
When using several IDELAYCTRL only one has to be constrained leave the others unconstrained.
Where do you get the information that the max value of C_NUM_IDELAYCTRL is '3"? I can see it supports upto 16 in MPD file.
-XF
Observer sbonafede
Hi XF.
I don't know from which MPD you are telling this but i am attaching a sanpshot with this.
You can see at the top blue line there is written PPC440mc_ddr2_v2_1_0.mpd
Whereas the highlited portion tells you that max value of C_NUM_IDELAYCTRL parameter is 3
I am using version 10.1 with SP3
Waiting for your valuable inputs.
Regards.
Best of luck.
Hello.
all the errors are gone just by manually changing the idelay_ctrl.v and  the corresponding MPD file for DDR2.
Changes are done to extend the max value of C_NUM_IDELAYCTRL parameter from 3 to 4.
The moment i included the extra IDELAYCTRL everything was mapped successfully and bit stream generation is complete.
I don't understand one thing that is why EDK limited the number of IDELAYCTRL parameters.
thanks for all the co-operation provided by you people.
Regards.
Best of luck.
I thought you are talking about MPMC.
-XF
