ILA and ICON or top cdc?
hell first,I illustrate my projects:the main is microblaze and top logic,between them I use axi_fifo to commuciate.But now I meet a problem is how I capture my signals in top loagic.I have did some experiments,such as I take ILA and ICON in the microblaze,then I can capture correct data in microblaze,but when I net dataports of ILA to wires of top logics in order to capture signals in top logics,but I can't capture corrects data.After that,I add cdc in top logics to capture signals in top logics,but I can't run with error when using chipscope.please tell me what is the right way in capturing signals with microblaze?and relavent pdfs.thank you very much
Tags (4)
Scholar pratham
Re: ILA and ICON or top cdc?
@zhfsongsong Check if this helps
http://fileadmin.cs.lth.se/cs/Education/EDA385/HT10/documents/KaziChipScopeTutorial.pdf
http://www.xilinx.com/ise/embedded/chipscope_edk91lab.pdf
http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug750.pdf
-Pratham
Scholar pratham
-Pratham
OK,it helps me a lot,thank you
