rushabh0013
INTERNAL_ERROR:Xst:cmain.c:3483:1.56.16.1 - Process will terminate. For technical support on this issue, please open a WebCase with this project attached at http://www.xilinx.com/support.
We are going to 32-bit floating point using VHDL, and we don't have use multiple clock then also XLINX shows the same error. So if any one get solution then plz inform me.....
alexsvet
I have just submitted a webcase with exactly the same issue:
--INTERNAL_ERROR:Xst:cmain.c:3483:1.56.16.1 -
My project is quite different, I'll let you know if the support team finds the problem.
I also tried to synthesise  your project but your fpdiv.vhd module contains a bunch of VHDL errors:
ERROR:HDLParsers:807 - "D:/test/fpdiv.vhd" Line 80. m can not be used with range to.
ERROR:HDLParsers:3236 - "D:/test/fpdiv.vhd" Line 80. Can not determine the "others" values in aggregate. (LRM 7.3.2.2)
ERROR:HDLParsers:807 - "D:/test/fpdiv.vhd" Line 81. m can not be used with range to.
ERROR:HDLParsers:807 - "D:/test/fpdiv.vhd" Line 82. m can not be used with range to.
ERROR:HDLParsers:3236 - "D:/test/fpdiv.vhd" Line 82. Can not determine the "others" values in aggregate. (LRM 7.3.2.2)
ERROR:HDLParsers:164 - "D:/test/fpdiv.vhd" Line 124. parse error, unexpected PROCESS, expecting IF
