diama13
IP Core Axi4 Axi Lite
I have created an axi slave burst core(axi4) with create and import peripheral and i would like to add some registers which can be written and read through axi lite. Can anyone help me????
diama13
Could anyone help me?
dgisselq
Consider this blog entry describing how to generate an AXI-lite peripheral that passes a formal verification check.  While you could ask Vivado to generate this example IP, as of Vivado 2018.3 it doesn't pass the check.
Dan
ritakur
Please refer to the “Creating a New AXI4 Peripheral” section to create an AXI IP with register included, then you can modify the generated HDL source to add custom logic and make it as a custom IP.
http://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_3/ug1118-vivado-creating-packaging-custom-ip.pdf
dgisselq
@ritakur,
Does this mean that Xilinx has finally fixed the bug in their AXI-lite core?  As of 2018.3, it hadn't been fixed.
Dan
