IRQ_F2P interrupt only runs after cold boot
I am using SDK to code the ARM on the Zynq FPGA.
I set up IRQ_F2P[0] with the XPS_FPGA0_INT_ID for edge sensitivity.
It works the first time after cold boot, but not on subsequent re-starts.
This might be OK for the final product, but slows development since I have cycle power and program FPGA every time.
Below is my initialization.
Is some extra initialization needed?
Emmett
// Initialize IRQ Interrupt
// Xil_ExceptionInit(); this is an empty function leftover for backwards compatibility
// Initialize the interrupt controller driver (IntcConfig is static global)
IntcConfig = XScuGic_LookupConfig(XPAR_SCUGIC_SINGLE_DEVICE_ID);
if (NULL == IntcConfig) return XST_FAILURE;
InitStatus = XScuGic_CfgInitialize(&IntcInstance, IntcConfig, IntcConfig->CpuBaseAddress);
if (InitStatus != XST_SUCCESS) return XST_FAILURE;
// Connect the IRQ ISR handler to hardware
Xil_ExceptionRegisterHandler(XIL_EXCEPTION_ID_IRQ_INT,
(Xil_ExceptionHandler)XScuGic_InterruptHandler, &IntcInstance);
// Enable IRQ exception in the CPU
Xil_ExceptionEnableMask(XIL_EXCEPTION_IRQ);
// Connect a handler function to the IRQ interrupt
// Use XPS_FPGA0_INT_ID instead of XPS_IRQ_INT_ID for programmable sensitivity
InitStatus = XScuGic_Connect(&IntcInstance,XPS_FPGA0_INT_ID,
(Xil_ExceptionHandler)PLIntrHandler,
(void *)&IntcInstance);
// Enable the IRQ_F2P
XScuGic_Enable(&IntcInstance, XPS_FPGA0_INT_ID);
you could put the EOI in the init (for your use case), you should clear in your handler.
Hey @emmettbradford
Do you handle (and clear) the interrupt in your code?
Best,
Herbert
e,
One post is sufficient (no need to post in multiple places).
How are you "restarting"?  A PROG_b causes a full configuration of both the PS & PL.  A reset of the PS does not re-load the configuration of the PL.  Operation over JTAG (commands, re-loading) depends on what commands, and what is re-loaded.
PS == processor system
PL == programmable logic
Austin Lesea
Principal Engineer
Xilinx San Jose
If you resert the pl, without resetting the ps, then you may need to set the EOI during init. For example can you add the line in the interrupt init in your application Where XX is your interrupt ID
XScuGic_CPUWriteReg(&InterruptController, XSCUGIC_EOI_OFFSET, XX);
Thanks for the reply.
Here is my handler.
If I need to clear the interrupt here, I don't yet know how.
static void PLIntrHandler(void *CallBackRef, u32 Mask)
PLIntrCnt++;
u32 ReadData;
// Toggle an LED on the KR module
ReadData=Read_creg(0x0081);
if(ReadData & 0x80000000)
Write_creg (0x0081, ReadData & 0x7FFFFFFF);
else
Write_creg (0x0081, ReadData | 0x80000000);
while((Read_dreg(0x007F) & 0x00000002)==0) {Read_dreg(0x0030);} //Check empty flag and read out DarkOutFIFO
while((Read_dreg(0x007F) & 0x00000008)==0) {Read_dreg(0x0031);} //Check empty flag and read out RawOutFIFO
while((Read_dreg(0x007F) & 0x00000020)==0) {Read_dreg(0x0032);} //Check empty flag and read out CalOutFIFO
Hi stephenm,
I want to work and not hang when I stop and start debug in SDK, without power down.
I have testing this morning and see some other wierdness depending on where I toggle the LED, in or out of the PLIntrHandler.
So maybe it's a different problem altogether.
However, should I be clearing the interrupt at initialization and in the handler?
Emmett
   Add this to your handler an let us know if this works
    IntIDFull = XScuGic_CPUReadReg(&InterruptController, XSCUGIC_INT_ACK_OFFSET);
    XScuGic_CPUWriteReg(&InterruptController, XSCUGIC_EOI_OFFSET, IntIDFull);
I see these lines in XScuGic_InterruptHandler.
Is XScuGic_InterruptHandler something that runs at every interrupt?
Should I put these lines in my handler as well or in my initialization?
I put both lines in my handler and init.
It doesn't seem to make a difference whether in either or both functions.
On the 1st debug run after power on and FPGA config, the interrupt will run.
On repeated debug runs, the interrupt will eventually not run.
Please check my code to see if I did what you suggested.
Emmett
I never resolved this.
I made a workaround by changing my debug configuration to reset everything and program FPGA.
It takes longer though.
I would still like to get this working on recursive PS starts.
Emmett
