eilert
ISE 14.4-7 BSB wizard shows strange error dialog
I was just trying to create a Microblaze system for a ML506 Board.
When the BSB wizard reaches the Peripheral Configuration step and I click the Next Button the folowing Error message appears:
strane_BSB error
The Busy-Wheel mouse cursor is then running forever.
The error window vanishes when I klick the OK button, but then I'm stuck with the wizard at this point.
I tried this with ISE 14.4 and 14.7 on a Linux OS so I think the Versions in between .4 and .7 behave the same.
What causes this error?
Kind regards
  Eilert
eilert
Hi Achutha,
it's a Debian Squeeze installation.
Removing the ML506 default peripherals down to 1 COM port and the non-removable lmb-controllers made no change.
I just checked the Terminal output (which I should have done from the beginning).
There appears:
 ERROR:EDK:3409 - Error calling proc
   <CoreModel::ClockRequirements::update_clock_on_port>: syntax error in
   expression "abs(100000000.0)": missing close parenthesis at end of function
   call
________end of message (Eilert)_____________
This issue dates back to ISE 12.1 and has an answer record:
AR# 35648
Error caused by german or french language settings.
The workaround is still working:
$ export LANG=en_US.UTF-8
$ xps &
Kind regards
  Eilert
achutha
Hi Eilert,
I tried this in 14.7 on RHEL 5.6 machine and i don't see the issue.What is the OS are you using?
I seen some issues in the older version 13.x specific to IP or peripheral select,Can you try having only 1 peripheral(RS232_Uart) added and see if you still see the error?
Achutha
eilert
Hi Achutha,
There appears:
   call
AR# 35648
$ xps &
Kind regards
  Eilert
prokul
I do exactly as your instructions but still got the error.
I have 2 languages (viet and eng) for text entry but I already set to English.
I try $ export LANG=en_US.UTF-8
and $ unset LANG
but nothing works.
Could you help me with this?
