Buzzardbait
In ISE 14.7 Xilinx Notify tells me it can't connect to get updates.
Pardon me if I'm posting this to the wrong board but it was the closest fit that I could find. I'm a newbe to ISE 14.7 and if I launch Planahead I get a Xilinx notify message that says "Permanently Moved". Then I try various settings such as Direct and IE but they don't work. To try a Custom setting for the proxy I need to know the http:// address and port. I have no idea what these should contain.
I've noted in another post some other issues with the ISE 14.7 installation and I'd like to see if updates would help but I get the same message.
Can anyone help?
drjohnsmith
Easy answer is 14.7 is the last ISE.
Note:  There are two versions of 14.7 for windows
one that is W7 only, it does not work on W10.
The W10 download is actually a Oracal Virtual machine,
    which runs on W10, into which is installed a linux and a special version of ISE. 14.7
 If your having problems,
    check you have the right version for your machine
drjohnsmith
