Newbie aclaessen
In line assembler issue Xilinx XSDK for Zynq
I am trying to compile an application developed with the ARM DS-5 tools the Xilinx XSDK (14.04) IDE and compiler.
I have run into an in-line assembly code issue that seems to compile correctly on the ARM DS-5 ide but fails on the XSDK.
The module is in a directory “XilinxCode".
The code is in the file “xpseudo_asm_rvct.h” and has a 2009 Xilinx Copyright header.
The code segment in question:
static __inline unsigned long mfcpsr(void)
    register volatile unsigned int Reg __asm("cpsr");
    return Reg;
#endif
#define mtcpsr(v)        { register volatile unsigned int Reg __asm("cpsr");\
                                      Reg = v; }
The error message that I am getting is:
invalid register name for 'Reg'
I am new to low level bare metal programming and have no experience with in-line assembly. Anny help would be appreciated.
