In read or write transaction in AXI.what happen if data transaction is before address?
HI there,
I have question regarding transaction in AXI4 bus (or any other bus). What happens  in write any read action when data transaction (handshaking) occurs before  address  transaction (handshaking) ?
Will the data be written to the particular address?
Thanks in advance!!
Tags (4)
The AXI spec does not mandate which order data and address are asserted even though the diagram implies a relationship.
KR
KR
