Visitor bhuelsen
Include Opencv 2.4.11 libraries in Petalinux 2017.2
Hi everyone,
my actual petalinux 2017.2 project is dependent to use opencv 2.4.11.
By default opencv 3.x will be fetched if I build the rootfs.
I figured out that I can specify the preferred preferred version of opencv in
<PETALINUX_INSTALL_DIR>/components/yocto/source/aarch64/layers/meta-petalinux/conf/distro/petalinux.conf
by modifying
PREFERRED_VERSION_opencv ?= "3.% to PREFERRED_VERSION_opencv ?= "2.% .
benjaminh@memory-lab-pc:~/embedded_development/ultrazed_repo/software/petalinux_build$ petalinux-build --component rootfs
#[INFO] building rootfs
[INFO] sourcing bitbake
INFO: bitbake petalinux-user-image -c do_image_complete
Parsing recipes: 100% |##########################################| Time: 0:01:12
Parsing of 2446 .bb files complete (0 cached, 2446 parsed). 3236 targets, 224 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
NOTE: preferred version 2.% of opencv not available (for item opencv)
NOTE: versions of opencv available: 3.1+gitAUTOINC+92387b1ef8
NOTE: preferred version 2.% of opencv not available (for item opencv-dev)
NOTE: preferred version 2.% of opencv not available (for item opencv-apps)
NOTE: preferred version 2.% of opencv not available (for item opencv-dbg)
Initialising tasks: 100% |#######################################| Time: 0:00:07
Checking sstate mirror object availability: 100% |###############| Time: 0:00:19
But as you can see version 2.x of opencv is not avialable.
How do I have to modify the build system to install opencv 2.4.11?
Tags (3)
Visitor nicka
Re: Include Opencv 2.4.11 libraries in Petalinux 2017.2
bhuelsen, did you ever figure out how to do this?  I would like to do the same thing using the 2018.3 Petalinx tool chain.
