Incomplete HDF
I've been struggling without success to understand the reason of this problem. I've two microblazes and I want their caches connected to the PS DDR. To do that, I connect instruction and data caches to an AXI interconnect and then to one of the HP ports of the PS. Everything seems to go OK with Vivado but when I export the HW to SDK, the name of the PS DDR address map is missing.
Does anybody know what is happening?
Yaset
Re: Incomplete HDF
Can you share block diagram tcl?
Looking at the details I think this is an address mapping issue.
Achutha
Re: Incomplete HDF
Hi Achutha,
Thanks for answering.
You can find here after the .tcl of my block diagram. I've changed the port of the PS (one slave GP instead of one slave HP) to see if it had something to do with the problem but nothing changed.
Also, I 've attached an image of the address mapping where you can see that, in theory, the addresses have been assigned correctly by the tool.
Yaset
