Incorrect instantiation of user_logic file from pcore libraries
I have a number of pcore libraries, each has its own "user_logic.v" file. For some reason when PlanAhead 14.4 creates the hierarchical structure for the project it instantiates the incorrect "user_logic.v" file for a particular wrapper. It uses the same "user_logic.v"  files for all wrapper modules, as opposed to the corresponding "user_logic.v" files from the corresponding library.
Any suggestions on what I am doing wrong.
The PAO and PRJ files for each library all seem to point to the correct files and libraries. Although I think these files are only used by XPS.
Re: Incorrect instantiation of user_logic file from pcore libraries
In addition, each module that is instantiating a "user_logic.v" file includes specific library and use statements for the particular "user_logic.v" file of interest.
