Installing SDK on embedded linux platform
Greetings,
I'm trying to install a SDK iso image onto an embedded linux platform. I was able to mount the image on the platform without problems. I also created a symbolic link called "bash" in the bin directory and had that point to busybox to satisfy the first line of code in the installer: "#!/bin/bash". However, when I run the installer, I get an error:
"installer: applet not found"
I get the same error when I type "bash" on the command line. Is there a way to fix this?
Here is the first few lines of code that causes the error:
#!/bin/bash
DEBUG=${DEBUG:="0"}                 # Enables debugging options
LC_OPTION=${LC_OPTION:="prompt"}    # Licensing related variable
INSTALL_PATH=${INSTALL_PATH:=$HOME} # Default installation path
declare -r SCRIPT_NAME="`basename $0`"
declare -r SCRIPT_CALLED="$0 $*"
declare -r START_DIR="$PWD"
declare -r SCRIPT_ROOT=`cd $( dirname $0 ); pwd`
declare SDK_NAME
declare INTELCE_PKG_CONFIG=""
declare INTELCE_TFS_DEPS=""
function debug ()
    declare -r local debug_color="\e[00;36m" # Cyan
    if [ "$DEBUG" -ne "0" ]; then
        printf "${debug_color}DEBUG:\e[00m %s \n" "$@"
        if [ -f "$INSTALL_PATH/installation.log" ]; then
            printf "DEBUG: %s \n" "$@">> $INSTALL_PATH/installation.log
        fi
    fi
Thank you
vsiva
What does your embedded platform have? Unless it is an x86/Linux based Embedded platform, SDK will not work. Note that even if it is an x86/Linux based embedded platform, it is not officially supported.
