Instructions for building newlib in XSDK 2018.2
Can you provide instructions on how to build newlib library in XSDK 2018.2?
Best Regards
Gaute
Re: Instructions for building newlib in XSDK 2018.2
Please follow the below steps for building newlib with Linaro ABE script
1.Download ABE sources https://git.linaro.org/toolchain/abe.git/log/?h=abe
 2.untar it and run the configure script
 ./configure --with-local-snapshots= [PATH_TO_NEWLIB_TAR_FILE]
 You may end up with configure errors, It will report the prerequisite Binaries.
 3.run abe.sh and you need specify the resource name that you want to build [newlib or gcc ..]
 ./abe.sh --target arm-none-eabi --disable make_docs --set makeflags="CFLAGS="-O2" CXXFLAGS="-O2"" --build newlib
HI @gaute.nilsson,
Please refer
https://www.xilinx.com/html_docs/xilinx2018_2/SDK_Doc/SDK_tasks/sdk_t_create_new_libproj.html
Best Regards
Abhinay PS
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
Hello @abhinayp.
Unfortunately, this is not what I want.
What I need is instructions on how to recompile newlib 2.4.0 which is shipped with XSDK 2018.2.
That will be parameters to invoke the ./configure script for newlib, as well as relevant environment variables.
The reason I need this is because I need to modify some options in the library.
Best regards,
Gaute
Hi @gaute.nilsson
  1. You need to first compile the newlib --> configure here as per newlib readme
  2.  Include pre-built library to petalinux rootfs
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_2/ug1144-petalinux-tools-reference-guide.pdf
3. Then in XSDK, you can include libraries and write your application
https://www.xilinx.com/html_docs/xilinx2018_2/SDK_Doc/SDK_tasks/sdk_t_proj_libraries.html?hl=library
Best Regards,
Nutan
Best Regards,
Nutan
Hi @gaute.nilsson
https://github.com/Xilinx/newlib
Best Regards,
Nutan
Hi @nutang
What are the exact command line options Xilinx have used to build newlib for the arm-none-eabi target, used in XSDK 2018.2?
And what branch/tag have been used in the https://github.com/Xilinx/newlib repository?
We use Linaro ABE to build the newlib.
For more details go through this link: https://wiki.linaro.org/ABE site.
Scholar ericv
@gaute.nilsson
This may help as I've rebuilt Newlib.
I am not aware how configure can be used with SDK.
You should first run configure on a *NIX machine.
Make sure to override the default assembler /  compiler / archiver used with the --program-prefix=PREFIX and --program-suffix=SUFFIX  to match SDK's assembler /  compiler / archiver tools.
Set all the config options you want plus the 2 above and run configure.
Then create a project in your workspace and copy everything in there.
Make sure to disable the make auto generation and set the build command to make -f Makefile
I did not rebuild it with SDK, but on *NIX, and still...
I got hit a few snafus with tools I did not have on my machine.
@nmekala
I am able to build newlib in multiple ways, but I need to know exactly how Xilinx has built it.
We have done all our testing in the current version of newlib which is shipped in XSDK 2018.2.
Therefore it is crucial to us that a recompiled version of newlib is as close to this as possible.
I want to change only one build parameter and keep everything else the same as before.
Can you give some more info on how you set up ABE, and which repositories/release versions you use?
