Integrating SDK .elf file in .bit file - ISE 13.2
Hi everyone,
I would like to have a .bit file containing also the program file.
In the EDK project under the Elf file section the Sim and Imp fields are empty and I've found no way to fill them with my elf file.
Does anyone can explain what to do to have this bitstream?
Thank you in advance!
Andrea Albano
bdSound srl www.bdsound.com
Re: Integrating SDK .elf file in .bit file - ISE 13.2
What do you mean by "no way to fill them with my elf file"?
Just select your elf in Project --> Select Elf --> Implementation and run Update Bitstream.
