jakkapat123
Interface between MicroBlaze and VHDL
Help
I am currently using Vivado 2017.1 with a Artix-7  50T FPGA.
I am trying to find out how to transmit Vhdl data pass microblaze.
hbucher
@jakkapat123 Microblaze lives in AXI/component space.
The easiest way to do this is to package your VHDL data into an AXI component.
If your data is a simple scalar that the microblaze has to be polling, it is better to implement an AXI Lite.
I did this tutorial for someone last month http://www.vitorian.com/x1/archives/594
Here is the full tutorial
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2017_1/ug1119-vivado-creating-packaging-ip-tutorial.pdf
hbucher
